Yealink trusted certificates
Discussion in 'Ideas' started by Antoine A. Telerys, Sep 27, 2017.
Yealink trusted certificates 5 5 4votes
5/5, 4 votes
  1. Antoine A. Telerys
    Jan 31, 2017
    17
    I'm pretty sure it's been asked before, but would it be possible to have the possibility to disable the trusted certificate option of Yealink phones within the Template or the phone config tab ?
    It is a huge handicap to permanently log into the phone GUI only to disable this option every time we have a firmware update/template/etc... And making a custom Template for this sole option is not reliable.
    Thanks.
  2. Silly English Kniggit
    Sep 13, 2017
    220
    89
    The problem is that it's on by default. A firmware reload or factory reset sets it back to on, and you lose control of the phones. We've stopped recommending Yealink phones because of this. The only other option is to use custom DNS and Yealink trusted SSL certificate on 3CX which is extra work, but does work.
