Solved Yealink - Username & Password after provisioning
Discussion in '3CX Phone System - General' started by TechXperts, May 19, 2017.
  1. TechXperts
    May 19, 2017
    Hi Guys,
    Would you know what the username and password resets to after provisioning the phones?
    Yelling T20 & T22
    The default before provisioning was admin & admin.
    Thanks,
    TechXperts
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Go in 3cx, extensions, double click on said extension, phone provisioning tab, and look at the phone web password (or something like that). Password is randomly generated by 3cx.
    TechXperts likes this.
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Hi TechXperts,
    You can find the password on Management console=> Extension => double click on the extension => Phone Provisioning tab => Phone Web Page Password. Also the username is admin.
  4. TechXperts
    May 19, 2017
    Thanks all for replying. Is there a "Thanks" Button? How do I close the thread, or you don't do that?
    GiannosC_3CX likes this.
