I'm not using the default template, who does?!
on Windows, try Notepad+I'll do an in depth comparison of template differences
Glad you were able to narrow down the issue. You might want to consider the following guide when creating a custom template. Yealink phones have some specific requirements when it comes to templates.So it does work on a default template, I'll do an in depth comparison of template differences and do some testing.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
