yealink versus dreamwave
Discussion in '3CX Phone System - General' started by engin411, Sep 8, 2012.
  1. engin411
    engin411 New Member
    Jul 3, 2009
    172
    Has anyone used Dreamwave phones with 3CX? Supposedly, dreamwave is the OEM, and Yealink rebrands them. I know 3CX has templates to provision Yealink phones - I suppose that those templates would probably not work with dreamwave-branded phones because of firmware differences.
    Dreamwave branded phones seem to be significantly less expensive than Yealink phones.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    In answer to your question, no, I have not used Dreamwave. In fact, a Google search reveals few hits and Google shopping showed no hits when I tried using the Dreamwave model number for the SIP-D28P unit. While I have no way to prove it, I am somewhat skeptical that Dreamwave is the OEM. The Yealink portfolio of phones is much larger and if you look at the support site under downloads, the Dreamwave site only shows downloads as recent as 2009. If they are indeed the manufacturer, it seems to me that they would have an even broader array of phones and be more prolific about their suppoprt. It almost appears as though they are the one who have rebranded the phones in order to present a complete product line in support of their IP-PBX offerings.
    In any event, I have seen Yealink phones branded as Cortelco, Agnitel, Alloy, et al. The Yealink name seems to be the one most in use and they have suppport websites in various geographic areas of the world, so my guess is that Yealink is the parent.....but I could be wrong.
  3. engin411
    engin411 New Member
    Jul 3, 2009
    172
    Yeah, I might have it backwards. Thanks for the comments.
