Yealink W52P second account
Discussion in '3CX Phone System - General' started by Willy, Sep 16, 2016.
  1. Willy
    Sep 16, 2016
    I would like to setup my yealink W52P with a second account.
    3cx (V14) initializes the first account automatically.
    But every try to setup a second account fails.
    I tried in the 3cx Management console - there i get the error message, that the MAC Adress allready is bound to one extension.
    I tried in the W52P Web Interface - setting up manually also does not work (registration at 3CX fails).
    Deleting the first account and setting account 1 manually with the account data for the second one works.
    But there is no chance to set up 2 Accounts.
    There a 2 handsets connected to the W52P
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    Only one account (account 1) can be provisioned by 3CX.
    All 4 other accounts have to be setup manually.
