Yealink W52P/W52H Final Firmware Version
Discussion in '3CX Phone System - General' started by AlexanderHanna, Aug 13, 2017.
  1. AlexanderHanna
    AlexanderHanna New Member
    Oct 2, 2015
    100
    12
    Hi Everyone,
    I am about to purchase 100 Yealink DECT W52 cordless phones. However, I noticed on the 3CX supported page that they reference a firmware number as being the "final firmware version". Does this mean that 3CX will soon stop supporting this phone? I don't want to be buying this phone if shortly after there will not be any more development for them.
    Lastly, if this DECT model is coming u on end of life, what other DECT cordless options are there?
    Thanks,
    Alexander
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,249
    202
    #2 Saqqara, Aug 13, 2017
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    The Yealink W56H/P is the newer product. Base station is the same as the W52P. The main difference is larger screen size and a lithium ion battery on the W56 models. I wouldn't purchase end of life W52 phones unless you get a significant price difference from the W56 model.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Hi Alexander,
    How are you doing?
    As far as I know the W52P is NOT End of Life.
    The firmware of the W52P base can be upgraded to 25.80.0.15 which is exactly the same firmware as running in the W56P base. And the firmware is compatible with the firmware of W52H/W56H handsets.
    The Yealink DECT phones are supported by 3CX. https://www.3cx.com/sip-phones/
    So I think it is save to purchase the Yealink W52 DECT phones.
  5. AlexanderHanna
    Oct 2, 2015
    100
    12
    Hi Frank, I am doing good. Yes, I see that both phones are supported by 3CX and both are listed as "final firmware version" on 3CX site.
    If you look at how 3CX reference lets say the Yealink T21P/E2 it says "min. firmware version".
    Thank you CentrexJ. As mention, 3CX mentions both phones in the same way as "final firmware version"
    Thank you Saqqara, will also check out the the Sonm.
    I am hoping that this is just the incorrect wording that 3CX used.
    Thank you
