Yealink W52P
Discussion in '3CX Phone System - General' started by ntnetzeband, Oct 19, 2017.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    Does anyone know if you are able to put multiple Yealink W52P DECT stations around an office and the wireless phones will automatically use the closest one? Or is each base station tied to one phone?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Not possible with this class of products
  3. ntnetzeband
    Jul 30, 2016
    65
    5
    You mean only for Yealink? Or all DECT products?
  4. sip.bg
    Nov 7, 2016
    704
    219
    Panasonic KX-UDS124 with handsets KX-UDT111/121/131 and some high-end Gigaset DECTs support multi-cell operation.
    May be some other brands too, I have tested the above with 3CX.
    Yealink is not making multi-cell DECT solutions.
  5. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
  6. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    Reading the link, you have to register the handsets with each base thus you are limited to 5 handsets per base - not sure if it works as we have never tried it.
    Depends on the setup - no of phones, size of building, etc you are probably better off with multi-cell solution.
