Yealink W56P
Discussion in '3CX Phone System - General' started by gigaboy, Jul 6, 2016.
  1. gigaboy
    Jul 6, 2016
    7
    Anyone know if this DECT phone will be officially supported in the next few months?
    Thanks,
    Mark
  2. carolinainnovative
    May 4, 2009
    369
    5
  3. buckshome
    Sep 8, 2016
    I would also like to request support for the yealink w56p !!
    Thanks!
  4. 3cxBora
    Jun 17, 2015
    35
    Is there any recommendation how to manually configure this to work on v14? Will W52P template work?
    TIA,
    Bora
  5. carolinainnovative
    May 4, 2009
    369
    5
    At first glance, the W52 template seems to work. Registered, made internal calls, etc.
    Will advise in a day or so if this is a semi-permanent solution.
  6. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    In the Yealink W56P Release Notes for v80 you can read what is add after v73, so within no time you have modified the 3CX W52P template. Now one template can provision W52P, W56P, W52H, W56H or combination of this sets.
    I have modified the template and it works like a charm.
  7. carolinainnovative
    May 4, 2009
    369
    5
    I did not even go that far. Using the 52's template worked like a champ, with the one exception of having to turn on nat traversal separately. Otherwise, the template worked without modification.
    Not a good answer for deploying a ton of them, but for one, not a bad answer.
    Do you by chance have a template you feel like sharing?
  8. jan.schreiber
    Oct 14, 2016
    6
    would you mind sharing your template?
    Thank you and kind regards
    jan
  9. Melvin_XIII
    Oct 25, 2016
    33
    I also have provisioned my Yealink W56P using the W52P template. It seems to work fine so far. I have however found one problem that I am told has to do with the provisioning template.
    I use the W56P in with the 3CX Windows Phone in CTI mode. when I dial a number in the CTI Phone it connects to the Phone with the "Make Call" dialogue. The line is on hold until the other end answers. I would like to have the phone ring instead of play music. Is this possible? Do I need to wait for the W56P to be officially supported?
    Thanks in advance
  10. complex1
    Jan 25, 2010
    752
    38
    This is the normal behaviour for the Yealink DECT phones (W52P and W56P) because the Base can not handle HTTP commands send by 3CX. Not even if 3CX officially support the W56P.
  11. Melvin_XIII
    Oct 25, 2016
    33
    thanks for the quick reply.
