Yealink weird behavior
Discussion in '3CX Phone System - General' started by craigreilly, Jun 2, 2017.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,284
    246
    T48
    Previously setup on Ext 200.
    Delete DEVICE from ext 200.
    Login to Phone GUI.
    Reset to Factory
    Login to Phone - no account details.
    Phone begins to reboot.
    When done - I login to phone again.
    It now has details for Ext 200.
    But under Phones in Management Console Screen Shot 2017-06-02 at 3.04.39 PM.png - it is a new device.
    I also tried again by REMOVING the credentials from the phone... saving - then RESET to FACTORY. It still got credentials...
    Also noticed - when I apply the 3cx Yealink T4x Template - 2 things happen:
    1) Phone GUI is only accessible via HTTPS. Not HTTP.
    2) The Dial Codes for DND on and DND off are no longer shown.
    I do not think this is necessary but noticed:
    static.network.dhcp.option60type
    should probably be static.network.dhcp.option60type= (the = sign is missing)
    #1 craigreilly, Jun 2, 2017
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Maybe you have an old config file for that extension from back when 3cx wasn't generating them on the fly ? When you delete the device from an extension, what happens if you navigate to your provisioning url / yealinkmac.cfg ?
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
  4. craigreilly
    Feb 1, 2012
    3,284
    246
    Jason - good call. For some reason there was just 1 CFG file in the directory and it belonged to this phone.
    No other handset is in there... lets see what happens now. :)
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Nice. Pulled my hair out on that one once. ;)
    #5 JasonNadeau, Jun 5, 2017
