Yearlink Speaker phone Randomly Picks up the phone.
Discussion in '3CX Phone System - General' started by smallcocomputing, May 18, 2016.
  1. smallcocomputing
    Apr 20, 2016
    I have been having a little bit of an issue lately in my office. Random phones will pickup an incoming call with the speaker phone and the client will be on the line without an employee answering. Its a little random and I am now starting to collect data to establish a reason this is happening. Located below is the only time it happened today.
    I am going to continue taking data so that I can see what is happening. I did search the forums but didn't find a topic on the issue. The 636 671 7146 # is the one that was picked up with speaker phone without anyone touching it.
    Yearlink t27p
    Sip Provider Flowroute
    17-May-2016 17:37:54.520 Call(C:1202): Call from Extn:105 to 6362323027 matches outbound rule '10 Digit Dial'
    17-May-2016 17:37:54.518 [CM503001]: Call(C:1202): Incoming call from Extn:105 to <sip:6362323027@10.0.0.25:5060>
    17-May-2016 17:37:54.518 NAT/ALG check:L:1202.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    17-May-2016 17:37:27.969 Currently active calls - 1: [1199]
    17-May-2016 17:36:55.967 Currently active calls - 1: [1199]
    17-May-2016 17:36:25.966 Currently active calls - 1: [1199]
    17-May-2016 17:35:53.964 Currently active calls - 1: [1199]
    17-May-2016 17:35:33.435 Leg L:1200.1[Line:10000<<+16364487140] is terminated: Cause: BYE from PBX
    17-May-2016 17:35:33.435 [CM503008]: Call(C:1200): Call is terminated
    17-May-2016 17:35:33.431 Leg L:1200.3[Extn] is terminated: Cause: BYE from 10.0.0.55:5060
    17-May-2016 17:35:33.147 Leg L:1201.1[Line:10000<<+16366717146] is terminated: Cause: BYE from PBX
    17-May-2016 17:35:33.147 [CM503008]: Call(C:1201): Call is terminated
    17-May-2016 17:35:33.143 Leg L:1201.5[Extn] is terminated: Cause: BYE from 10.0.0.45:5060
    17-May-2016 17:35:21.962 Currently active calls - 3: [1199,1200,1201]
    17-May-2016 17:34:51.960 Currently active calls - 3: [1199,1200,1201]
    17-May-2016 17:34:19.959 Currently active calls - 3: [1199,1200,1201]
    17-May-2016 17:33:47.957 Currently active calls - 3: [1199,1200,1201]
    17-May-2016 17:33:42.053 Leg L:1201.2[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    17-May-2016 17:33:42.052 [CM503003]: Call(C:1201): Call to <sip:101@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    17-May-2016 17:33:42.041 Leg L:1201.6[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    17-May-2016 17:33:42.040 [CM503003]: Call(C:1201): Call to <sip:103@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    17-May-2016 17:33:42.039 Leg L:1201.3[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.55:5060
    17-May-2016 17:33:42.038 [CM503003]: Call(C:1201): Call to <sip:102@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.55:5060
    17-May-2016 17:33:42.014 [CM503007]: Call(C:1201): Extn:105 has joined, contact <sip:105@10.0.0.45:5060>
    17-May-2016 17:33:42.013 [CM503007]: Call(C:1201): Line:10000<<+16366717146 has joined, contact <sip:85694727@sip.flowroute.com:5060>
    17-May-2016 17:33:42.011 L:1201.5[Extn] has joined to L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:42.011 NAT/ALG check:L:1201.5[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    17-May-2016 17:33:41.922 Leg L:1200.4[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.0.0.7:5060
    17-May-2016 17:33:41.921 [CM503003]: Call(C:1200): Call to <sip:104@10.0.0.25:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.0.0.7:5060
    17-May-2016 17:33:41.906 Leg L:1200.5[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.45:5060
    17-May-2016 17:33:41.904 [CM503003]: Call(C:1200): Call to <sip:105@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.45:5060
    17-May-2016 17:33:41.898 Leg L:1200.2[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    17-May-2016 17:33:41.891 [CM503003]: Call(C:1200): Call to <sip:101@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    17-May-2016 17:33:41.887 Leg L:1200.6[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    17-May-2016 17:33:41.886 [CM503003]: Call(C:1200): Call to <sip:103@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    17-May-2016 17:33:41.778 [CM503007]: Call(C:1200): Extn:102 has joined, contact <sip:102@10.0.0.55:5060>
    17-May-2016 17:33:41.777 [CM503007]: Call(C:1200): Line:10000<<+16364487140 has joined, contact <sip:85694727@sip.flowroute.com:5060>
    17-May-2016 17:33:41.775 L:1200.3[Extn] has joined to L:1200.1[Line:10000<<+16364487140]
    17-May-2016 17:33:41.774 NAT/ALG check:L:1200.3[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    17-May-2016 17:33:40.630 Leg L:1201.4[Extn] is terminated: Cause: 486 Busy Here/INVITE from 10.0.0.7:5060
    17-May-2016 17:33:40.629 Call to T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] from L:1201.1[Line:10000<<+16366717146] failed, cause: Cause: 486 Busy Here/INVITE from 10.0.0.7:5060
    17-May-2016 17:33:40.629 [CM503003]: Call(C:1201): Call to <sip:104@10.0.0.25:5060> has failed; Cause: 486 Busy Here/INVITE from 10.0.0.7:5060
    17-May-2016 17:33:40.542 [CM503025]: Call(C:1201): Calling T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] for L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:40.537 [CM503025]: Call(C:1201): Calling T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] for L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:40.531 [CM503025]: Call(C:1201): Calling T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] for L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:40.526 [CM503025]: Call(C:1201): Calling T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] for L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:40.521 [CM503025]: Call(C:1201): Calling T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a] for L:1201.1[Line:10000<<+16366717146]
    17-May-2016 17:33:40.479 [CM503027]: Call(C:1201): From: Line:10000<<+16366717146 ("Main DID - 6362254545:BELL, TODD" <sip:+16366717146@10.0.0.25:5060>) to T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a]
    17-May-2016 17:33:40.479 [CM503004]: Call(C:1201): Route 1: from L:1201.1[Line:10000<<+16366717146] to T:RingAll:800@[Dev:sip:101@10.0.0.48:5060;line=da56b8b6b1615b7,Dev:sip:102@10.0.0.55:5060;line=b9330564e7e31d5,Dev:sip:104@10.0.0.7:5060,Dev:sip:105@10.0.0.45:5060;line=e04f64620cfd341,Dev:sip:103@10.0.0.43:5060;line=7926a944a5d8a3a]
    17-May-2016 17:33:40.477 [CM505003]: Provider:[FLowRoute] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:85694727@47.50.165.26:5060]
    17-May-2016 17:33:40.476 [CM503001]: Call(C:1201): Incoming call from Line:10000<<+16366717146 to <sip:800@10.0.0.25:5060>
    17-May-2016 17:33:40.476 Line limit check: Current # of calls for line Lc:10000(@FLowRoute[<sip:85694727@sip.flowroute.com:5060>]) is 3; limit is 8
    17-May-2016 17:33:40.476 NAT/ALG check:L:1201.1[Line:10000<<+16366717146] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,253
    63
    The phone that is randomly auto-answering, do you have a 3CXPhone for Windows in CTI mode on the same extension?
  3. jholcombe
    Jul 9, 2014
    79
    I had something similar to that occur a while back. User A and B are in the same ring group. User A is on a call. When another call comes in and user A tries to answer it, user B's phone picks the call up on speakerphone. I never did find a solution to this problem and it could still be an issue.
    post172903.html#p172903
    --John
