Yeastar TDM800
Discussion in '3CX Phone System - General' started by spyker, Oct 21, 2009.
  1. spyker
    Oct 21, 2009
    Hi guys,
    question will the Yeastar TDM800 card work with the 3cx free edtion. if so how do you set it up in the appplication.
    any adivce will be very help full.
    Thank you!
    Regards.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    No it wont. There are no Windows drivers for the Yeastar cards. The only PCI cards that will currently work are Sangoma cards that are supported by Sangoma's Netborder Express.
  3. spyker
    Oct 21, 2009
    Hi Kerry,
    I found windows dirvers for the Yeastar TDM800 card at
    Is it possible to add the card to the pstn device list?
    Thanks in advancde
    Regards
  4. KerryG
    Jun 19, 2009
    960
    There is no standard for Windows drivers for TDM cards. Just because they have a driver doesn't mean squat since there is no industry standard for how to communicate with the card. I really don't want to see 3CX have to try to deal with every card out there. It needs more than a driver for 3CX to talk to it, Sangoma does this with their Netborder Express software which talks to the card and provides a SIP trunk that 3CX can talk to.
  5. stevenrca
    Nov 8, 2010
    Please do not use Yeastar products, we had lot of bad experience and we have lost lots of money. Their service is very bad most of praise of product is their internal marketing techniques...
    Their products is cheap and saves money initially ... but thats all... nothing works after that. The staff who can understnad little bit of English dont want to know your problems other than more orders and the staff who dont know english just dont want to work. So you end up loosing time, money and even business.
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    THe Yeastar PSTN cards are not supported and will never be.....
