- Joined
- Jun 15, 2015
- Messages
- 6
- Reaction score
- 0
Hi everyone,
I am trying to integrate Zoom Rooms with 3CX. (https://support.zoom.us/hc/en-us/ar...gest=ccc31f59e727594613a39e30b3f4bdb3ae0ce5e2)
They officially offer SIP PBX support and I've gotten the extension to register correctly.
This is the extension:
This is the Zoom setting screen
And it registers correctly:
I can call extension 242 from extension 205 and answer them in Zoom without a problem.
But when I try and call extension 205 from the Zoom extension 242 it doesn't work.
Why would incoming calls work fine but outgoing calls not?
Code:
09-Mar-2017 12:57:27.979 Leg L:5749.3[Extn:242] is terminated: Cause: BYE from PBX
09-Mar-2017 12:57:25.274 Leg L:5749.4[Extn:242] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.70:57186
09-Mar-2017 12:57:25.186 [CM503007]: Call(C:5749): Extn:242 has joined, contact <sip:[email protected]:5060>
09-Mar-2017 12:57:25.182 L:5749.3[Extn:242] has joined to L:5749.1[Extn:205]
09-Mar-2017 12:57:25.181 NAT/ALG check:L:5749.3[Extn:242] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
SIP contact header is not equal to the SIP packet source(IP:port):
Contact address:192.168.1.140:5060
Received from :192.168.1.140:57716
09-Mar-2017 12:57:23.234 Leg L:5749.2[Extn:242] is terminated: Cause: 486 Busy Here/INVITE from 192.168.1.140:5060
09-Mar-2017 12:57:23.228 Call to T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob] from L:5749.1[Extn:205] failed, cause: Cause: 486 Busy Here/INVITE from 192.168.1.140:5060
09-Mar-2017 12:57:21.624 [CM503025]: Call(C:5749): Calling T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob] for L:5749.1[Extn:205]
09-Mar-2017 12:57:21.620 [CM503025]: Call(C:5749): Calling T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob] for L:5749.1[Extn:205]
09-Mar-2017 12:57:21.615 [CM503025]: Call(C:5749): Calling T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob] for L:5749.1[Extn:205]
09-Mar-2017 12:57:21.566 [CM503027]: Call(C:5749): From: Extn:205 ("Firstname Lastnane" <sip:[email protected]:5060>) to T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob]
09-Mar-2017 12:57:21.566 [CM503004]: Call(C:5749): Route 1: from L:5749.1[Extn:205] to T:Extn:242@[Dev:sip:[email protected]:5060;rinstance=8fc1e7e5539ed6e7,Dev:sip:[email protected]:5060;rinstance=1085264ea18656a3;transport=tcp,Dev:sip:[email protected]:57186;rinstance=0-ca7070866f5d4e2e86847c935a260e70;ob]
Code:
09-Mar-2017 13:01:12.169 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 192.168.1.140:5060 tid=08cf737e916f576e Call-ID=OWJiNTQ5NzE3ZDljNmE3ODZhZmQ1NzVhZThlZTdhMTI.3c2e9b8@192.168.1.140:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.1.140:5060;branch=z9hG4bK-d8754z-08cf737e916f576e-1---d8754z-;rport=5060
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: <sip:[email protected]:5060>;tag=1b1cd27e3c2e9b8
Call-ID: OWJiNTQ5NzE3ZDljNmE3ODZhZmQ1NzVhZThlZTdhMTI.3c2e9b8@192.168.1.140
CSeq: 2 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: INVITE, ACK, CANCEL, BYE, INFO, OPTIONS
Content-Type: application/sdp
Proxy-Authorization: Digest username="242",realm="3CXPhoneSystem",nonce="414d535c0ed12c4778:46053204434c3e97538f22bae197637e",uri="sip:[email protected]",response="7f720f5a3b172d9b23ab6aa57fe8c4db",algorithm=MD5
Supported: timer
User-Agent: ZoomSIPPhone
Content-Length: 276
v=0
o=Zoom_VideoGW 185567 185567 IN IP4 192.168.1.140
s=Zoom VideoGW
c=IN IP4 192.168.1.140
b=AS:1000
t=0 0
m=audio 9184 RTP/AVP 9 0 8 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
09-Mar-2017 13:01:12.169 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from 192.168.1.140:5060 tid=08cf737e916f576e Call-ID=OWJiNTQ5NzE3ZDljNmE3ODZhZmQ1NzVhZThlZTdhMTI.3c2e9b8@192.168.1.140:
Max-Forwards: 70
CSeq: 2 INVITE
Min-SE: 90
Supported: timer
Content-Length: 276
v=0
s=Zoom VideoGW
b=AS:1000
t=0 0
a=fmtp:101 0-15
a=sendrecv
09-Mar-2017 13:01:12.169 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE [email protected] tid=08cf737e916f576e cseq=INVITE [email protected]:5060 / 2 from(wire)
09-Mar-2017 13:01:11.191 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from 192.168.1.140:5060 tid=b41be8732aa06b19 Call-ID=OWJiNTQ5NzE3ZDljNmE3ODZhZmQ1NzVhZThlZTdhMTI.3c2e9b8@192.168.1.140:
Via: SIP/2.0/UDP 192.168.1.140:5060;branch=z9hG4bK-d8754z-b41be8732aa06b19-1---d8754z-;rport=5060
Max-Forwards: 70
CSeq: 1 INVITE
Min-SE: 90
Supported: timer
Content-Length: 276
v=0
s=Zoom VideoGW
b=AS:1000
t=0 0
a=fmtp:101 0-15
a=sendrecv
