- Joined
- Aug 15, 2017
- Messages
- 500
- Reaction score
- 57
Android is V9, Xperia XZ1
When I use the "Telecom API", the majority of called or calling partys will tell me the microphone level is to low. Increasing the gain will not change their experience.
When I make a call using the standard options, the microphone amplification is ok (and using the gain option will change the amplification), however pressing the volume up or down keys will not change the speaker volume. For me the volume of the speaker (not using headset) is too loud.
If I remember correct this problem exists since several month now, but I cant remeber exactly at what beta version this started.
