Unsupported 2N Verso video calling
George Kyriacou
Hi does anyone know if it is possible to carry out video calls from a 2N verso to the IP desktop phone? I understand this would be very dependant on the model of handset, can anyone confirm what model Yealink would support this ? For example would the SIP-T58W-PRO work?
thanks
You just need to check if the Yealink T58W and 2N devices support the same video codec. If yes, then the video call would work between 2N and Yealink phones.
So the fact that is going via the 3cx system will have no relevance?
thanks for the assistance, i will check this out.
Phone supports
Video codec: H.264 High Profile, H.264, VP8 • Video quality: 720P (1280x720)-30fps ( ≥ 512 kbps
2N Verso supports
2N may require a license to enable H.264 , so that you can change the settings
thats a great help thanks
Finatra.us
