Solved 3cx Client 15.5.345.642: ignores no vibration checkbox
nobody
When I start the program it makes the phone vibrate two times for no apparent reason. I unchecked vibrate in the advanced options, but no change.
Also, after a missed call again the phone vibrates four times.
Can this be fixed? Besides from the checkbox which has no effect, i see no reason for the program to vibrate at startup then that the programmer was proud of learning a new option he could annoy users with.
Or, is there reason for this behaviour?
We'll check this.
What phone are you using?
This is an xperia XZ1 compact. Oreo, patch level sept. 2018
Followup: I checked this with a note8, Oreo, Patchlevel Oct. 2019. No bad vibrations here. only good silence.
I have installed 15.5.345.643 on the sony. The Problem is gone. I thought the ony difference was the quit disabling push which is again availible in this version?
Anyway this topic can be closed.
cvanderzwan
