- Joined
- Sep 11, 2023
- Messages
- 368
- Reaction score
- 47
I would like some guidance on the necessary ports to open on the firewall in this guide https://www.3cx.com/docs/manual/firewall-router-configuration/
It's indicated
From sip provider:
5060 TCP & UDP
5061 TCP
9000-10999 UDP
But if I don't open the UDP files from 9000 to 10999 to any, the audio cannot be heard
To use Click2Talk to call fqdn the 3cx https port and 5001, however, I had to create a rule for the caller that can go out on TCP 5001.
With the new installations will everything run on the 443?
Here too I needed the udp ports from 9000-10999?
It's indicated
From sip provider:
5060 TCP & UDP
5061 TCP
9000-10999 UDP
