Solved 3CX phone for android videocall from Akuvox door phone
mkb
Gold Partner
Hi all,
I'm trying to setup-up a video call from Akuvox video door phone (E11) to 3CX phone for android.
Audio works great, but I can't get video to work.
After all the time spent on this I'm wondering if it could possibly work at all.
The Akuvox video settings are a little limited. Can someone point me in the right direction?
Akuvox Model E11
3CX android 16.5.2.55
3CX 16.0.6.655
Best regads
I believe the payload should be set to 99 ... ;)
The reason is that H264 codec is not supported by the client, only VP8 is.
cvanderzwan
