Solved 3CX Webinars” plugin Error
onkanisa
I have been deploying a 3CX Webinars” plugin on my web press website , Everything seems to be fine except that my website dont display schedule web meetings.
It only shows meetings created with the Webinar profile.
I have created the meetings in my Webinar profile yet nothing is displayed but no error
Have you added the shortcode to a page?
I did uploaded the short code to my page
Okay, did you enter the right extension in the Webinar plugin config? So that it takes your list and not another user's. Also, check the FQDN to be sure it's the WebMeeting one, and not the PBX's.
I did enter the right extension in the Webinar Plugin config , FQDN is also the webmeeting
I checked and redo everything and I am getting this error now : Webinar API error: Invalid reply
Hi Okanisa,
Can you PM me a screenshot of you WebMeeting Webinars plugin configuration?
The plugin definitely works, this must be some type of misconfiguration that can easily be fixed.
Thanks a lot for the assistance, i deactivated chatt plugin, delete webinar plugin and reinstall it again and both plugin worked very well, thanks again
VOIPEric
