400 Bad request
SimonDeLaplace
Intermediate Cert.
Hi all,
after v18 upgrade i have this error. It happens only when i click on conferences button or a conferences links on the same server.
the NAT of 5008 port works fine (i had to setup 5008 when normally is 5008)
In another server the error is different, is about cookie
Likely you are doing natting on your firewall of 5001 to 5008. And trying to nat to the http port instead of the https port.
You should change the PBX port itself to 5008 if you want that port.
No, i set the pbx to use 5008.
remote https login works, only in the VC tab and vc links not works
Graham Robertson
