Solved accidentally leaving a Conference room
safespothotline
Hello all!
Is there a solution for when an agent is on the phone with a caller, then creates a conference by adding another caller (everyone gets moved into Conference room) and then the agent accidentally exits the Conference -- they can't get back in because it doesn't show up in the panel. I can see that it is still open on the back end in the admin active calls section, but there isn't a way to rejoin. I have tried calling that agent's conference ID, etc, but none of it works. Thank you!
Hi @safespothotline if you are the meeting organizer, then using the 3CX app you have to enter in the MEET section, there you see the LIVE conference and can click the redial button or add other participants too, please check the pic below:
Solution
Hey Alejandro. We just tested this and did not have any conferences appear in the MEET section. Here are screenshots from the back end.Screenshot 2026-11-18 132400.png
and here is the active call list showing the conference with the agent gone
So here is the scenario more detailed:
Person calls the hotline. AGENT answers. Person experiences an overdose while on the line with us. We conference in 911. Conference room 700 is created when those calls are all merged. Now by accident, the AGENT hangs up and leaves Conference 700. I can still see PERSON in the Conference room (they are unresponsive). Even if 911 hangs up, the Conference stays open as long as PERSON is connected. We just have not way of getting AGENT or ADMIN back into the Conference. I have tried dialing 700, and I don't have anything in the MEET tab.
Thanks so much!!
The 700 is the conference extension, is not the room number. In the meet section the organizer is the one that see the active conference there, not other users. Make sure you are checking it with the organizer user extension.
This works as shown in my screenshots, I have double checked the scenario unless you are doing something special and is not being mentioned in the steps...
OMG, that was the trick. It has to be the conference organizer, aka AGENT, who goes back in to find the conference and rejoin. Admin is not able to do that. THANK YOU. This is literately a lifesaving thing you just helped with!!!
(I also figured out how the agent can do it from the app, so extra kudos for that being a working feature). THIS IS WHY 3CX is the best!
youwillbrun
