Solved Android client not able to receive inbound calls
GereMarie
Multiple users in my organization have reported issues receiving inbound calls when they upgraded to 16.7.6. I know that many people are having this issue. From my research there is no solution as of yet.
Hi @GereMarie,
  1. What happens when you call them?
  2. Are the extensions receiving calls normally (without the App)?
  3. Do they receive a notification / missed call or nothing at all when receiving a call?
  4. Does this happen to every 16.7.6 version of the Android App or only specific extensions?
Hi @VasilisV_3CX
1. Their desk phone rings and their desktop app rings, but their android phone only receives a notification that someone called or left a voicemail.
2. Yes
3. Not on the android phone.
4. Yes, all of the phones affected are using a 16.7.6. All extensions that are using an android phone have this issue.
Yes I tried testing on wifi and turning off Telecom API. Same issue. Please let me know what other information you would need. I appreciate the help.
Hi @GereMarie,
As per the link:
'Every post must contain the following details
1. The subject must be a short summary of the problem including the version number example "V16.2.0.41-Problem calling when connected to Mobile data (LTE)"
2. We will need the following information filled out and added to the intro of the post:
  • Phone Model: [HTC Desire | Samsung Nexus S...]
  • Android Version: [Android 10]
  • App Version: [16.0.1.X]
  • 3CX PBX Version: [V16 Update 7 (16.0.7.1078)] / [Windows | Debian | Raspberry Pi]
  • Network Connection: [WiFi | LTE] / [IPv4 | IPv6]
  • Client is on the same network as the PBX or not?
Depending on the issue, it might be good to also mention any other specifics that may be related. Some examples could be:
  • Issue happens only with BT headphones connected
  • Happens when battery is low and Power Saver is enabled
  • DND mode is enabled
  • etc'
I reverted to default firebase settings and this fixed the issue. Thank you.
Great to hear @GereMarie, if you need any further assistance feel free to open a new thread.
cvanderzwan
