Audio Dialin in Webmeeting possible?
JM_Hamburg
Forum User
Dear Forum Members,
i read in Threads from 2018 that it will be possible to dialin via Phonenumber in a Webmeeting. Is this still possible and when how?
I tried every way i tried but i was not able to get an Audio dial in into a working Webmeeting.
Thank you, and hopefully looking for an Solution.
Greetings from Germany, Hamburg. I am Using V16 latest Version.
Jens
First, you need a Pro or Enterprise license.
Then, you dial 700, it will ask for the conference ID then press #. It will connect you audio-only.
I have a PRO licence but i dont understand how i get the conferenz ID. I just startet a webweeting. But Dialing 700 will not pick up the line.
If i start Audio only : yes i will get an Conferenz-ID but this will not connect through the webmeeting.
Audio will only work with audio only through the 3CX itself. And yes this is working, but i have read that you can combine dial-in and webmeeting. So again, is this possible?
The meeting ID is available in the Webclient meeting page and during the meeting via the "Add Participant" button. However, instant meetings (clicking WebMeeting on the Webclient instead of scheduling a conference, even if it's right now) don't have an ID. Only scheduled ones, even if scheduled for now.
Reactions: JM_Hamburg
Thank you very much, that´s the point. Now i am happy. Greetings from Hamburg, germany.:-)
