Solved Automatic status change when joining webmeeting
MH_INDUS
Hello all,
In 3CX v16 the status did not automatically change to dnd when opening or joining a webmeeting.
Is this planned to be added to 3CX v18?
Kind regards
Hi!
I am not aware of any current plans to automatically set your 3CX Extension Status when you join a 3CX WebMeeting.
Technically speaking, joining a meeting does not "block" you from receiving calls, and because you would be joining a meeting using a Web Browser, very likely from the same browser you have your WebClient open in, or the same PC that you have your Desktop App installed on, you can easily with 2 clicks change your status.
Also there are some challenges, when you are the scheduler of the meeting, OK, but when you are simply invited by someone else, it opens in the browser, your extension is completely unaware that a meeting is going on.
Hi there,
There are plans to add this feature, however there is no clear timeline for the implementation of this.
Hello NickD_3CX, Hello LeonidasG,
thanks for the heads up.
Graham Robertson
