Best way to support multiple customers
Rick-Arcus-IT
Platinum Partner
What would be the best way to support multiple 3CX systems? I'm sure it would be strange to get access to the Meta developer portal of the customer to build the 3cx-whatsapp app. Could you support multiple apps in 1 meta developer account in comination with different PBX systems and whatsapp business numbers?
Regards,
Rick
Hello!
This case should not cause any problems. PBX is configuring to work with a specific number and token. It's not important how these things managed.
I understand that, but what I would like to know is if I can create multiple apps under 1 meta business account.
It should be ok. Meta has own limitation on amount of apps, but probably this limit depends on account.
skander
