Click2Dial detecting/dialing every number on a page — any server-side (Admin Console) controls for number detection?
itsernst
We're rolling out the 3CX Click2Dial browser extension (Chrome/Edge) to our users and running into a problem with over-detection.
Setup
  • 3CX V20 (self-hosted), Web Client / PWA
  • Click2Dial extension configured with Web URL = https://<our-fqdn>
  • Users dial from the web client (no desktop app / TAPI)
Problem
On certain websites, the extension is turning every number on the page into a clickable dial link — order numbers, IDs, dates, etc. — not just actual phone numbers. When a user clicks any of those numbers, it tries to place a call.
Constraint
I can't just exclude the whole site, because legitimate phone numbers live on the same URL(s) as the false positives. So a domain-level exclusion / "disable on this site" would kill the numbers we actually want to dial.
What I'm looking for
The per-extension options seem limited, and it feels like some detection controls are missing. My questions:
  1. Are there any Admin Console / server-side settings in 3CX that control Click2Dial number-detection behavior (e.g., what qualifies as a phone number, minimum digit length, detection on/off) — pushed down to clients rather than set per-browser?
  2. Is there a way to make detection stricter (e.g., only match tel: links or properly formatted numbers) instead of scanning all page text?
  3. If this can only be managed at the extension level, what's the recommended approach for a site that mixes real phone numbers with lots of other numeric data on the same page? Is select-to-dial (manual highlight, auto-detection off) the intended fallback?
Click-to-Dial is on the browser level and is not managed from the PBX. This will use the tel: protocol. Web sites with standard tel: protocol tags are automatically recognized and made clickable urls that will redirect to 3CX in order to make the call.
If the problem website is under your direct control, then change the sites code, so "tel:" links are rendered by the site directly only where needed, and then add it to the exclusion list of the 3CX Click2Call browser extension.
Jake_Southern
