Solved Conference Callin via Phone does not work. People keep hearing the onHold-music
Tappsy
Hi everybody,
i got a strange problem here. If someone tries to join a webmeeting via phone, they keep hearing the onHold-music forever, after entering the meeting-id and pressing the #-button. I can see them in the participant-list of the webmeeting with their phone-number, but the audio connection does not work.
I really have no idea where to look at. Does someone maybe have a hint?
Kind regards
Tappsy
Hi @NickD_3CX,
yes sorry, of course:
3CX Version: 16.0.9
Server OS: Debian 9
Is the 3CX Server Hosted and where?: No, on-premise
IP Phone Make/Model/Firmware: n/a
Provisioning Method: Local / VPN / STUN / SBC: n/a
Trunk Provider or Gateway Make/Model: Vodafone
Has the Firewall Checker passed: YES
Are custom Phone Templates being used: NO
But i can't rerun the Firewall Checker right now, because of the service-restart and a lot of people are using it right now.
But maybe this helps: I have found the following entry in the event_log when someone tries to join via phone:
Device wm2198079@(Ln.90000@WebMeeting bridge) had no available outgoing trunk(s) for Call(48931)
I there maybe a problem, because we had a test-trunk from another provider while first testing 3CX. Do i need maybe need to reconfigure something there?
Kind regards
Tappsy
Hey Tappsy,
When you find the right time, I think you should re-run the Firewall Checker just to be sure.
In the meantime, in your Management Console go to SIP Trunks, click on "WebMeeting bridge" and check:
  • In the General tab that you have enough Sim Calls (default value is 50)
  • In the Advanced tab, that all "Allow inbound calls", "Allow outbound calls" and "Supports Re-Invite" options are checked
  • Still in the Advanded tab, make sure you have codecs G711u, G711a, G722 and GSM-FR
Reactions: Tappsy
Hey @NickD_3CX,
you made my day!
This one:
was the solution for me. Allow in- & outbound calls was not checked!
Now it works like a charm!
Thank you!!
Kind regards
Tappsy
Glad I could help and that it's up and running again! :)
Reactions: Tappsy
Hassan Murasan
