Solved Fanvil X6U SIP Registration Failed
BGPrescott
Good day,
New 3CX system. 3 Phones are working, 3 are not. All of the phones are Fanvil X6U. 3 work properly and 3 do not.
On the non working phones, I have rebooted. I have factory reset each of the 3 non working phones and then reapplied the settings, yet I continually get SIP Register Fail.
Incoming calls work on all Phones, but outbound calling does not work on the non registered phones.
My Server / Setup Info:
  • 3CX Version, Standard 18.0 Update 3 (Build 461)Version
  • Is the 3CX Server Hosted and where? Hosted by 3CX
  • IP Phone Make/Model/Firmware version, e.g. Fanvil X6U version 2.4.12
  • Provisioning Method: STUN
  • Trunk Provider VITELITY
I am unsure as to why 3 work and 3 do not.
Suggestions?
The problem was resolved. The problem was caused by the SonicWALL SIP Transformation option was turned on (Thanks to another VoIP Provider who turned it on).
Once I turned it off, the phones worked properly.
I hope this may help someone in the future.
Saqqara,
Thank you for the response. As I mentioned in my response, the problem was with the SonicWALL router configuration. But your link and recommendations are appreciated.
Yes, a SBC is going in tomorrow.
Reactions: JohnS_3CX
