- Joined
- Oct 13, 2022
- Messages
- 5
- Reaction score
- 0
Hi!
i have a feature request. Please add a funktion that i can globally activate a quality surveillance for all my users.
there is a 3cx with quality problemś and with 30users. it is not clear when exactly the issue is present nor the user. The most calls are fine. So i had to activate the surveillance at any single user.
Now i need a chiropratic for curing my mouse clicking finger ....
Can you add a fuction button in the users section of the admin console to activate in a global way? It would be very kind of you !
Best regards!
1. will grafana be nessesary to watch this dashbord or is it implemented in the 3cx?
2. will the surveillance be enabled by default to use this feature or still manually activated? (my thought: will it impact the nessesary machine power?)
3. is the function able to alarm if calls reach a bad threshold?
THX!
Best regards!
KyriacosS_3CX
thx for the fast reply: unfortunatly i cant answer so i hope that you read this:1. will grafana be nessesary to watch this dashbord or is it implemented in the 3cx?
THX!
Upvote
