From Where and How can I generate these certificates for MS teams in 3CX integration part?
Uasgher
New User
How can I get the private key and these certificates?
The private key is known only to you and is what is used in conjunction with the CSR to generate the certificate. You can check what is provided to you by the Certificate Authority, used to generate the certificate. Or simply cancel the certificate and re-issue it through the provider keeping hold of the private key (coping the private key) when you go through the new certificate generation process within the certificate authorities portal.
@Uasgher
The instructions to configure Teams with 3CX can be found here:
https://www.3cx.com/docs/microsoft-teams-business-voice/
Specifically about the Certificates that you asked about, as mentioned in Step 2, the certificate you generate can't be from any CA, it needs to be from one that is in the MS approved list that we link to.
Stephan Eusebe
