Green bars during a video call
voipdevice
Platinum Partner
During the call to the BAS-IP video intercom from 3CX Android app, the sound works correctly, but the remote picture is not displayed. Instead of picture, there are green bars are displayed. At the same time, a call from the application to the Fanvil i10v intercom works correctly. Is it possible to change video settings in the application?
If you only use the mobile data(5G) the issue is the same?
Is it the same for all users? On a different network still the same?
The call from another device, user and network the same
@voipdevice
Instead of Android client, please try WebClient or desktop client to check if there's the same behavior and let us know.
Call from WebClient and desktop windows client can't obtain remote video too. Local video only
The issue was partinitary solved by changing resolution of BAS-IP intercom to VGA 640*480 (before was 1280*720). 3CX app starts video session doubleside but for intercom call it should be one side video. For example BAS-IP mobile app works with 1280*720 correctly with one way video. And good solution for intercom will add DSS button to open the door in video session.
RJenkinsROCK
