Hi Salesforce Integration Token length
Posica
I have tried to integrate the Salesforce from the tutorial.
and it is the try use account now.
A problem about the security token length is over the 3CX supplied.
Salesforce token is more than 7 digit that 3cx could accept
Hello @Posica,
Thanks for bringing this issue to our attention, we will check this and provide a fix as soon as we can.
Meanwhile, maybe you can configure the security token length from Salesforce? Or if this is random, maybe you can try resetting it, and maybe next time you get a shorter one?
Kind regards,
I am very new to Salesforce ,
It is a random security token and when ressetting it , the length is as the usual.
I am not sure if it is about the trial-use license problem.
tks.
In my test account, the security token is only 24 characters length. So this is for sure something that can be adjusted somehow. Just guessing, but maybe it's related to the password length, and changing the password gives you a shorter token?
Stephan Eusebe
