Solved High fidelity Audio
heiko
New User
Hi there,
is there a way or a workaround to get better audioquality for the video conferencing? I would like to use Stereo sounds.
Thank you!
you can upgrade the meeting quality to the highest setting, which increases the bitrate for audio, however stereo is not supported in rec or playback
VOIPEric
