how an extension or number is used ?
luc.jubeau
Platinum Partner
Is there a solution to know where an extension or a phone number is used like a group, a queue, a call transfert or anywhere ?
Thanks for yours answers,
Luc
Hi @luc.jubeau
From what I can understand you would like to know if an extension is part of a group, a ring group, a queue, etc all in one place.
If this is the case it is not possible to do so unless you manually check, each ring group, queue, etc.
Finatra.us
