How is VoIP Security with Elastix? - Bulletproof!
MAM
3CX Support
MartinAlcantara submitted a new blog post
Hello friends
is it possible to put a tone music in elastix
example i install elastix and i want when we apel on an extension the musk plays like tone
if so then how do you do your help
Buenos dias
Pregunta, es para el tono de llamadas al exterior?
si no es asi, ya probo cambiar la musica en espera, por la seleccion de sonidos que necesita?¿?
I want when my call the GSM number that is in the simbox the music plays as tone
Hello @ib07
You can customize your music on hold, it means if you have a file with the tone in the format .wav pcm 16bits 8khz then you can use it as Music on Hold.
Themarketmindset
