Solved How to limit call to BLF button only
Cloudfactory
I want permit only the usage of BLF button to call on my Yealink T54W phone.
How to do ?
Hello @Cloudfactory,
Once you've provisioned the phone in the Management Console and added it to an extension.Click 'Extensions', select the Extension you chose and click 'BLF'. Set up the BLFs you'd like to use. Reprovision the phone and your BLFs should show up.
Yes, but i need to limit usage on three BLF buttons only, i dont want somebody use Menu button or can compose other internal number.
Thank you for clarifying.
By default there is no way to do this. You would have to do this via Custom Templates.
Ok Thank you i try to do this with my template.
Regards
Reactions: VasilisV_3CX
Finatra.us
