How to sort status view in android App
AWS2P
I'd like to see extensions sorted by their number as now it seems to be by name. So now everything in App is displayed in an happy mess.;)
Is there a way to set App to order by ext. number?
Another small problem , I get a group of extensions that stay displayed in App even if publish group infos is unchecked. it seems weird behavior with that technique group, when check is on or off, it seems produce no change and group stay always displayed, for another group on same PBX it was initially off and group was not displayed (so normal behavior) I checked it on and group has been displayed --> OK
What do to next?
What do to next?
Check if your in both groups. That would be why you see it even without "Publish to all".
Yeah. They recently changed that and now it's following the PBX (Adv > Contacts > Options) ordering. Which really suck.
There's no way to put it back to ext numbers, like they added back in the Webclient.
Is there any future Dev to add a setting to let user choose by himself how to sort list of extensions?
Finatra.us
