Unsupported huawei Emui
fabiog
SOHO User
The 3Cx app does not work on Huawei phones with EMUI, because Google services are not present and cannot be installed.
There is any alternative Voip App that can be used instead of the propritary 3CX to have it working correctly on huawei phones ?
The 3CX Android App requires that the android device in question is running Android 7 and above and that Google Services are pre-installed by the manufacturer.
That said, we do not support any third party softphones as none other than the 3CX Clients have been tested with 3CX so I can't really offer any suggestions. I'll leave this open though in case anyone else can provide some information.
Try Wave Lite or Bria or Zoiper. One of them might work.
Yes but How to configure one of this soft phones in 3CX, ?
They are not on the list of supported phones.
RJenkinsROCK
