Hubspot CRM Integration - Scope Issue - Nov 21 update
kiwi1234
Gold Partner
Intermediate Cert.
HI everyone
We are doing a 3cx install for a client that has hubspot (we have done lots of these in the past) and normally its a breeze to install.
Today is different, within the Hubspot Dev account and the APP the scope is different. It looks like this
We Save this and go to the 3cx do the normal Client ID and Secret and click Authorize. We select the correct account and get the following
I noticed at the top there was this message
I tried this link and got the following after clicking on the account, and it redirects back to the 3cx server
Error occured: Value cannot be null. (Parameter 'key')
Any help would be great thanks
Thanks for sticking at this edossantos, the reason I selected these is that the ones you mentioned are not lsited, so I selected the nearest ones...
Instead of crm.schemas.* select crm.objects.*.
crm.schemas.companies
crm.schemas.contacts
crm.schemas.deals
crm.objects.owners
crm.objects.contacts
crm.objects.companies
crm.lists
crm.objects.deals
Legacy​
Request
content
reports
social
automation
actions
timeline
business-intelligence
oauth
forms
files
hubdb
transactional-email
integration-sync
tickets
e-commerce
accounting
sales-email-read
forms-uploaded-files
crm.import
settings.users.write
conversations.visitor_identification.tokens.create
files.ui_hidden.read
crm.objects.marketing_events.read
crm.objects.marketing_events.write
crm.schemas.custom.read
crm.objects.custom.read
crm.objects.custom.write
settings.users.read
media_bridge.read
media_bridge.write
settings.billing.write
crm.objects.feedback_submissions.read
cms.knowledge_base.articles.publish
cms.knowledge_base.articles.write
cms.knowledge_base.articles.read
cms.knowledge_base.settings.read
cms.knowledge_base.settings.write
settings.users.teams.write
settings.users.teams.read
THX SOOOO MUCH!!!!!!!
Hi there,
I have the same problem.
Which settings do I have to make (click) in Hubspot so that it works?
Hi there,
Please note that you must use the updated template, which you can find in this same thread.
The scopes in the HubSpot app should be the following:
  • crm.objects.companies (read)
  • crm.objects.contacts (read and write)
  • crm.objects.owners (read)
  • timeline
BTW, before xmas we will release an update including the template supporting granular scopes for v18. Once we do this, we strongly recommend that you delete the custom template, and move to the official integration, so you can benefit from future updates.
Great! I can wait for it.
Hi @edossantos,
Is it possible to get the updated xml file here?
Thanks,
Reactions: edossantos
