Solved Hubspot drop down in 3CX console
Andy Dame
I am exploreing having Hubspot outdial and track calls from our hosted 3CX unit (Standard Annual V16.0.9). the info sheets say that there is a drop down option in the CRM tab. I was unable to find it. Any idea where it went and is the template availble touse?
You will need to upgrade to Pro or Enterprise to use the CRM Integration.
It is found under Settings > CRM > Server-Side Integration (the tab won't appear on Standard edition.)
The dropdown option is to select the CRM provider:
Reactions: edossantos
Thank you problem solved
Finatra.us
