Hubspot integration not journaling or creating contacts
ctiwi
After following the steps outlined here: https://www.3cx.com/docs/hubspot-pbx-crm-integration/ we are able to "test" the integration and look up contact information from Hubspot however we arent seeing calls get journaled against known contacts in Hubspot nor are we seeing new contacts being created for unknown callers.
I have ensured that Match exactly is selected on the Contact options within 3CX but no dice.
Below are the results when manually specifying a phone number for 3CX to use as part of a test contact lookup and testing the integration with Hubspot from the 3CX server. Note that sensitive info has been redacted however the lookup is successful.
Search Results
"UnparsedOutputs": {
"ContactID": "10201",
"FirstName": "Rob",
"LastName": "Stoner",
"CompanyName": "",
"Email": “REDACTED”,
"PhoneBusiness": “REDACTED”,
"PhoneMobile": “REDACTED”,
"FaxBusiness": "",
"ContactUrl": "https://app.hubspot.com/contacts/REDACTED/contact/10201"
"FirstName": "Rob",
"ContactUrl": "https://app.hubspot.com/contacts/REDACTED/contact/10201",
"CompanyName": "",
"PhotoUrl": null,
"ContactType": 0,
"PhoneBusiness2": null,
"PhoneHome": null,
"PhoneHome2": null,
"PhoneMobile2": null,
"PhoneOther": null,
"FaxBusiness": "",
"FaxHome": null,
"Pager": null
CRM Log
CRM Log
Started scenario with empty id
Started Auth
Request text: https://api.hubapi.com/oauth/v1/token
Request form value refresh_token set to REDACTED
Request form value grant_type set to refresh_token
Request form value client_id set to REDACTED
Request form value client_secret set to REDACTED
Response text: {"refresh_token”:”REDACTED”,”access_token”:”REDACTED”,”expires_in":21600}
Response finished
Variable AccessToken set to REDACTED
Variable ExpiresIn set to 21600
Finished Auth
Request text: https://api.hubapi.com/contacts/v1/search/query?q=+REDACTED
Response text: {"query":" REDACTED”,”offset":1,"has-more":false,"total":1,"contacts":[{"vid":10201,"canonical-vid":10201,"merged-vids":[],"portal-id”:REDACTED,”is-contact":true,"profile-token”:”REDACTED”,”profile-url":"https://app.hubspot.com/contacts/REDACTED/contact/10201","properties":{"associatedcompanyid":{"value...":[]}]}
Response finished
Variable ContactID set to 10201
Variable FirstName set to Rob
Variable LastName set to Stoner
Variable CompanyName set to
Variable Email set to REDACTED
Variable PhoneBusiness set to REDACTED
Variable PhoneMobile set to REDACTED
Variable FaxBusiness set to
Variable ContactUrl set to https://app.hubspot.com/contacts/REDACTED/contact/10201
Finished scenario with empty id
Result obtained
I use HubSpot and it all works.
first, make sure your phone numbers in the CRM are in the same format as your inbound CIDs. If +1 is there, put the +1 in HubSpot too.
Also, have you created the "app" in HubSpot?
Yep, app has been created and when entering a test phone number into the CRM test within 3CX returns contact information. Whats strange is that when 3CX receives a call from an unknown number no contact is created within Hubspot.
Have you enabled the contact creation in the integration? Also, you need to have free Contacts space in HubSpot (limited to 1000 on free CRM).
Yep, Contact Creation and Journaling are enabled in the integration. We are running Hubspot Free but only have ~120 contacts loaded in so far so we shouldnt be hitting that limit quite yet.
What is that [TC]? That will be interpreted as an unknown variable by 3CX and you will get an error. You should use the following to escape the opening and closing brackets:
{{TC}}
If this doesn't work, please enable verbose logs from the 3CX Console > Dashboard > Activity Log > Settings. Then make a test call, and check the 3cxSystemService.log file.
Finatra.us
