HubSpot Integration
speedhost
New User
We want to integrate HubSpot. But we don't find HubSpot in the integration list. Settings>CRM
We attached a screenshot. Please advise us.
Shahadat
Shahadat
The HubSpot integration is server-side. From your screenshot, since it does not appear as a tab (Server-side), it means that you are using a Standard license. You need to upgrade to Pro or Enterprise to get the CRM integration.
