Solved iOS: 3CX Webmeeting app icon
Sepultura
Forum User
I've just installed the iOS 3CX Webmeeting app and I've noticed that it has the same icon as the phone app. I suggest to use a different icon because this will confuse users.
Hi there!
The Branding for the 2 products is the same as we see it as a single product: 3CX
Well, then of course this is a good idea :p
To be honest: I've never ever had two apps showing the same icons, even if it is for apps of the same product. Imagine all Synology diskstation apps showing the same icon or even better all Gmail suite apps showing the same icon o_O
I suppose if you pin the icons at the bottom of the screen, you lose the text, so I see your point.
Certainly something for us to consider.
But if the apps aren't pinned, the text should help users tell them apart.
Hassan Murasan
