Solved iOS WebMeetings App doensn't redirect on Safari
pedaa
the iOS-MeetingsApp does not open automatically on iOS (iPadOS) when I click on a link in the calendar. Why? WebEx does it!
Could you check this?
Best regards pedaa
Hi there,
This was an issue with one of the first releases of iOS 14. Could you try updating to the latest iOS and try doing this again?
I reinstalled the app on iPad OS 14.3. but the problem exists on the current System, too.
Hi there,
Looks like the problem is back. I have in IOS 14.3 again stopped working. On devices with IOS 14.2 installed, it works as expected.
Today I installed the test version of WebMeeting 10.7.0.119. Links still do not open. If the link comes to the chat, copying and pasting is a big headache. It is not possible to copy only the link, the entire text of the message is copied and it must be edited.
I would assume that Apple broke it again on those versions.
Our team will reopen the case with them for iOS 14.4
Good day! Did you manage to test your work with IOS 14.4 beta?
I am using the latest TestFlight beta (they probably have a more recent internal build) and iOS 14.4 beta 2.
Still not working.
Apple has released a new version of iOS 14.4 RC (Release Candidate). Is the specified problem solved in it?
Deeplinking remains broken in 14.4 and it is confirmed by Apple Developer Support without any workaround. For us is the workaround to remove Deep Linking support and build a guided way to jump into the app from the portal page. The team is already working on it as it appears we can no longer rely on the currently used method.
x1515
