iPAD 4th Generation with iOS/10.3.4 and Webclient not working.
Musarano
i just got the device to be able to make some changes remotely to the remote instance, but it doesn't go further than the initial centered 3CX logo,
Is it a way to get around this?
Thank You
PS: The 3CX APP is running ( Latest compatible )
@Musarano
As far as I remember you have to enable in device Settings/Safari/Request Desktop Website be ON.
Thank You Vali, i had tried that and neither, the logo stays there and no login section will be displayed.
Could it be that Ram is only 1 GB and one single CPU?
Hopefully this can be fixed or get around it... is just what i would wish. :)
If you run the 3CX client on the same iPad, does it show the green "Available" status on top right? Has presence in Team? If not, then almost for sure there's a problem with the PBX's FQDN / QR code.
AshleyStokes
