Issues with Salesforce Integration
Kris G.
I'm wondering if someone can help me here, I've recently integrated 3CX into Salesforce and am receiving the following errors when testing.
I should note that this is a relatively new instance of Salesforce with API enabled, so I have not created any custom contact fields.
Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason=Bad Request - Content=[{"message":"\nContact(Id,FirstName,LastName,AssistantPhone,Fax,HomePhone,MobilePhone\n ^\nERROR at Row:1:Column:72\nNo such column 'AssistantPhone' on entity 'Contact'. If you are attempting to use a custom field, be sure to append the '__c' after the custom field name. Please reference your WSDL or the describe call for the appropriate names.","errorCode":"INVALID_FIELD"}]
Started scenario with empty id
Started Auth
Request text: https://login.salesforce.com/services/oauth2/token
Request form value grant_type set to password
Request form value client_id set to somethingsecure
Request form value client_secret set to somethingsecure
Request form value username set to [email protected]
Request form value password set to somethingsecure
Response text: {"access_token":"somethingsecure","instance_url":"https://mydomain.my.salesforce.com","id":"https://login.salesforce.com/id/somethingsecure","token_type":"Bearer","issued_at":"1564175125632","signature":"somethingsecure"}
Response finished
Variable Url set to https://mydomain.my.salesforce.com
Variable AccessToken set to somethingsecure
Finished Auth
Request text: https://mydomain.my.salesforce.com/services/data/v37.0/search/?q=FIND {5551234} IN PHONE FIELDS RETURNING Contact(Id,FirstName,LastName,AssistantPhone,Fax,HomePhone,MobilePhone,OtherPhone,Phone,Email,AccountId),Lead(Id,FirstName,LastName,Fax,MobilePhone,Phone,Email,Company),Account(Id,Name,Fax,Phone)
System.Exception: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason=Bad Request - Content=[{"message":"\nContact(Id,FirstName,LastName,AssistantPhone,Fax,HomePhone,MobilePhone\n ^\nERROR at Row:1:Column:72\nNo such column 'AssistantPhone' on entity 'Contact'. If you are attempting to use a custom field, be sure to append the '__c' after the custom field name. Please reference your WSDL or the describe call for the appropriate names.","errorCode":"INVALID_FIELD"}]
at CrmIntegration.ScenarioProcessorBase.ProcessRequest(ScenarioRequest request, IValueManager customManager, HttpClient client, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.Execute(ProtocolScenario scenario, CancellationToken token)
at CrmIntegration.CrmProcessor.GetContactInfoFromCrm(String contactNumber, String destinationEmail, Boolean createIfNotFound, CancellationToken token)
TEST
Check your Field Level Security on 'AssistantPhone' on the Contact object. looks like your Salesforce profile can't see it right now.
That was it! Thank you sir / ma'am.
Reactions: edossantos
You're very welcome Kris. I've come across that in the past and it broke my heart! :p
Paul
11655
