Lets Encrypt For Private Meeting Server V20
illcsales
Got an email today for renewal of cert for private meeting server is there not a script that automatically renewals for the MCU like those using 3CX FQDN?
Your certificate (or certificates) for the names listed below will expire in 19 days (on 2024-09-12). Please make sure to renew your certificate before then, or visitors to your web site will encounter errors.
We recommend renewing certificates automatically when they have a third of their total lifetime left. For Let's Encrypt's current 90-day certificates, that means renewing 30 days before expiration. See https://letsencrypt.org/docs/integration-guide/ for details.
xxxxxx.my3cx.net
For details about when we send these emails, please visit: https://letsencrypt.org/docs/expiration-emails/ In particular, note that this reminder email is still sent if you've obtained a slightly different certificate by adding or removing names. If you've replaced this certificate with a newer one that covers more or fewer names than the list above, you may be able to ignore this message.
For any questions or support, please visit: https://community.letsencrypt.org/ Unfortunately, we can't provide support by email.
To learn more about the latest technical and organizational updates from Let's Encrypt, sign up for our newsletter: https://letsencrypt.org/opt-in/
If you are receiving this email in error, unsubscribe at:
Please note that this would also unsubscribe you from other Let's Encrypt service notices, including expiration reminders for any other certificates.
Regards,
The Let's Encrypt Team
Reactions: Nathan@Voxtelesys
Hello @illcsales , you can update your onboard MCU server to latest release using
apt update ; apt -y upgrade
This should activate the auto update for the certificate.
If the certificate is already expired, you can safely delete the Meeting Server from System / Conferencing / Video and create a new one. Then you can reinstall the server with the latest version (and the new FQDN)
@MarcelloV as you can see from the post it hasn't expired, I will run the update but why was that not there by default, was it an oversight?
@illcsales some very early OnBoard installation had this problem. In the meanwhile we added other features, for example automatic updates.
Great thanks for the clarification...
Reactions: MarcelloV
arming
