Location of webmeeting recording?
oschobert
Gold Partner
Hi!
Where are webmeeting recordings located? I would like to access the recording to remove or rename it because i don´t want anyone who received the link to access this file.
Thanks a lot!
Hi @[email protected]
only the meetings organizer is given the recording URL if a meeting as been recorded.
Hense no one else (unless shared) should be in possession of it.
We already shared it to externals. How can we access the source?
Which directory does it point to? If i would knew this i could remove or rename the file.
the recording is a non-discript file name hosted in your portal in the cloud. There is no access for you or us to this. It is programmatically deleted after 7 days. You may consult with 3CX Support if there are some ways.
We already contacted support whithout response untill now.... Could you help?
I'm also having problems getting 3CX webmeeting recordings. Can someone help?
x1515
