Longest waiting time polling
dr15
Hi, with longest waiting time, does this mean that if an agent A is logged in, and another agent B logs in and out then back into the queue, agent A would technically be the longest idle even though he may have taken more calls in between agent B logging in and out?
Basically, does the counter restart if agents log in and out and back into the queue?
Yes, the timer resets. You can also see that in the switchboard. Since the person is present (time stamp) from the moment he logs in and is availble.
Just to confirm, this means an agent could be logging out and back in, which resets the timer, and therefore is less likely to get a call than another agent who has been logged in for longer?
Yes, you can see in the queue (switch board) when a person logged out and logged in again.
Finatra.us
