MCU Connection Failed 0x0020
Ecki
we are experiencing the error "MCU Connection Failed 0x0020" during the creation of web meetings.
We have checked the firewall logs and the required servers for the 3cx video conference cloud platform (https://www.3cx.com/blog/voip-howto/video-conference-server-optimization/)
and are seeing at least one 3cx ip beeing blocked by our firewall because it has been flagged malicious.
For example https://www.abuseipdb.com/check/164.90.202.110
I know this could be solved by disabling the filter on the firewall and therefore reducing security..
Is there a way to change 3cx default behaviour and maybe have it retry if the ip is not reachable?
Is this solvable if the local MCU is used? Or will v18-vc-qos.3cx.net still be in use?
The video conference region is currently set to europe.
Thanks in advance!
Bash:
# nslookup v18-vc-qos.3cx.net
;; Truncated, retrying in TCP mode.
Server:         XXX.XXX.XXX.XXX
Address:        XXX.XXX.XXX.XXX#53
Non-authoritative answer:
Address: 170.64.145.108
Address: 34.176.174.48
Address: 35.221.175.237
Address: 142.93.238.81
Address: 34.35.69.212
Address: 158.160.170.22
Address: 157.245.108.209
Address: 167.172.102.66
Address: 158.160.173.12
Address: 164.90.202.110
Address: 188.166.157.144
Address: 20.233.253.21
Address: 170.64.163.104
Address: 142.93.52.187
Address: 142.93.62.154
Address: 170.64.225.88
Address: 68.183.38.148
Address: 34.35.67.34
Address: 167.71.231.53
Address: 34.35.48.161
Address: 146.190.48.212
Address: 164.92.177.252
Address: 206.189.24.168
Address: 158.160.173.82
Address: 188.166.156.218
Address: 34.176.3.76
Address: 20.233.252.141
Address: 46.101.139.138
Address: 35.247.196.146
Address: 20.233.253.25
Hi @Ecki , the IP address you are referring to was not running our services at the time of the report. Dynamic MCUs are on demand servers which are started only when needed to handle the load. This specific server was started today at 08:03:19 UTC, so it's totally unrelated to the malicious activities reported by "abuseipdb".
I must say that these kind of reports are pretty useless (if not dangerous) because these IPs can be reassigned every hour to a different server running a different service.
There is also a retry mechanism... after 120 seconds, if the meeting doesn't start on the assigned MCU, another MCU is selected from the pool.
Of course, if you use the OnBoard MCU feature you're in complete control and you get the best security.
arming
