Solved Meeting not found
yetopen
Hi.
Since last week's outage we're still having issues with WebMeetings.
It works if you use direct link, but when inviting someone from within the conference, or when doing a scheduled one, the recipient gets Meeting not found error when clicking the link.
Also when inviting someone from within a call the participant popup doesn't seem to update: you add someone, click ok, when opening it back the list is not updated with the added ones.
We tried restarting PhoneSystem01 and PhoneService01. We also changed the server from Automatic (which was Poland, I noticed) to Germany but it's still the same.
Is there anything else we can do to check?
thanks
I have had similar problems in the past. Restarting the 3CX System Service (as directed by 3CX support) has fixed the issue. I've seen others confirm the solution.
Reactions: yetopen
Rebooted the whole server fixed, thanks
Reactions: JohnS_3CX
Graham Robertson
